Honda not running
Hi, did you check the sparkcoil and the magnet if they are with rust there maid be a bad spark ore no spark. Clean the rust and try again. mcHarley
Only on the coil MOUNTING pads where the coil GROUNDS out on purpose.
Flywheel and other coil rust has nothing to do with magnetism.
Saying that, clean and polish your coil and flywheel magnets to fresh metal. Won't hurt a thing.
