phildunford
- Nov 13, 2026
- 5
My X125 has a weird starting problem. Starter engaged but did not have the power to turn the engine over. It seemed like a flat or dodgy battery - so bought a new one - same problem.
Starter relay looked corroded, so fitted a new OEM one and cleaned up all the terminals and leads in the high current path and crimped on new spades on the low current side. - same problem.
Made up new high current leads, a bit thicker than original. Same problem.
Replaced starter motor (not OEM, but looked decent). Exactly the same problem.
The engine runs fine once it starts. Sometimes it turns over fairly well, sometimes the engine just seems to stall the starter and it gets hot - very inconsistent.
It almost seems that sometimes the engine is very hard to turn over - yet when I turn the 'fan' on top by hand, it seems OK.
No idea where to go from here. Any clever people with bright ideas??
P.S. The deck is not engaged - I can see the drive belt is loose, so there is no load on the engine.
