Briggs and Stratton Model 44N877 Type 0003G1
Better than the clear window caulk.
GE 100% clear silicone is a fabulous product. Often wondered if it would be good on valve covers and the like. I know it has vinegar which is acidic. Not good on aluminum parts and such that can corrode.
ok.., so i got new manifold seals, also purchased new govenor/idle spring kit. Still waiting for the gaskets (2) for the carb coming tomorrow. Is there a trick to putting on the the bowl without moving the black gasket? Appreciate the assist!!!
Is that black gasket new?
If not the carb will usually leak because the fuel will bypass the needle/seat. (seems strange but true) You can verify such (leakage) by applying about 3-5 lbs air pressure to the inlet barb with the carb inverted.
Here is one link, but several if you search.
try this link for parts/ they are reasonable on prices and shipping but site is not user friendly for finding parts. (search using a Briggs part number that you found elsewhere) When you see Nikki parts numbers they are actually Briggs part numbers.
Also for Briggs Nikki parts check out sawzill parts.com click on the menu link in the upper left corner and select Briggs for the Nikki parts list.
Stihl Chainsaw Parts | Husqvarna Chainsaw Parts | Sawzilla Partsct
when i pulled the needle and looked down it's hole..there was no seat (brass or rubber)...., shouldn't there be?
when i pulled the needle and looked down it's hole..there was no seat (brass or rubber)...., shouldn't there be? NO
Here is a link with pictures of Nikki carbs diss-assembly.
If you do not have a low pressure 3-5 pounds source to check the inlet try using soap and water, like looking for a tire leak. Install a 1/4 hose onto the inlet barb and blow into the hose with the top upside down (float up) and the needle tip wet, move the float up/down and see if the needle seats with only the weight of the float. Most generally the needle/seat is ok if clean, but keep a heads up on replacement needle, some are just not same size as the OEM. (close but no cigar) If the black gasket is leaking it bypasses the inlet needle/seat and the carb will leak/flood. If the needle is leaking you can see such also using the soap/water. If the black gasket is used and old it leaks after being disturbed.
