This is a 1986 Kawasaki 17h and the water pump is on the front. When removed the radiator to replace the thermostat there was no thermostat or gasket. I have both new and can't tell by the drawings if there should be two gaskets, top and bottom or only one. If only one, which side of the thermostat should it be?What engine do you as the IPL is showing air cooled FC420V engines?
Hello N.,Trying to understand what the order of placement for the thermostat and gasket is
