Gtx 1054 fuse block
dugin
Hello all, new guy here, my gtx1054 has a 4 place fuse block, third space from the top is empty, is this normal or did I loose a fuse? bought mower second hand and it came with electrical tape over fuses I had an issue earlier and removed the tape and didn't replace it. If fuse is missing what do I replace it with amperage wise. looked at the wireing diagram but no help there, Thanks for Any and all help.
GTX1054 Tractor (2012) (14WZ94AK010 (2012)/14AZ94AK010
Sounds like you have power steering model.
Can't tell which fuse as you would trace the wires but likely it the one for the stator(alternator) which would be a 30A. If you are able the start and drive the mower. Operator manual does not show the fuse block.
Normally according the schematic there is 2 ea 40a, 1 ea 30a and 1 each 20A
Hello D.,
Did you verify it has retainer fins to hold both sides of the fuse?
I could also be for a auxiliary lighting or electric power steering system.
If the option is not installed the slot may have been left empty on purpose.
