Fuel stabilizers mean the fuel is good forever?
Auto Doc's
Community Leader
As the title suggests, stabilizer in fuel means it will last forever, right? Read on.
Do you just dump a best guess amount of stabilizer in the fuel tank(s) or fuel cans? Do you think "more is better" will make fuel last longer? It does not. Follow the direction on the product container.
Is the fuel "new" that was in the ground tanks at the station when you purchased it? Probably not.... The only advantage is that it has had less oxygen/air exposure to prevent rapid breakdown. It still breaks down in the ground tanks and during transport.
Was it still new when you used it out of a fuel can that has been sitting for a couple of months? That only means the fuel was only "new" once upon a time.
How long can fuel sit in a fuel tank of a typical mower, especially in summer heat? A week, two weeks, a month?
Over many years, I have used/tested just about every proclaimed fuel stabilizer only to find out that:
1: Ethanol fuel will "phase separate", chemically split in just a couple of months and loose volatility pretty quickly.
2: Non-Ethanol fuel tends to last much longer with and without stabilizer.
3. Any fuel that is exposed to air absorbs humidity and eventually forms water droplets in the fuel; Ethanol fuel just does this at a faster rate.
I will not suggest the "best" fuel stabilizer because some work better than others in different regions and weather conditions. That just turns into a never-ending debate, so I suggest keep your fuel as fresh as possible and use what works for you.
Just never assume that you buy fuel in January and expect it to still be good when August rolls around. All fuels are a perishable commodity, and the market is experimenting with different fuels all the time to limit the longevity so they can sell more on a daily basis. In many areas of the country/world they have "Winter or Summer blend" fuels so the mixture is constantly changing.
My experience has been to run the equipment dry at the end of a season, then pull the carburetor and clean the bowl and the rest of the carburetor before putting it back into service when the next season comes.
I will also not claim newer fuel injection equipment will not be any better, because it just adds more complexity to cleaning or keeping the fuel system clean.
If anyone has not experienced fuel stabilizer turning to gel from aging, you have been lucky, because it will happen with equipment left sitting for exceedingly long periods.
Never believed in it myself , I just pour a little marvel mystery oil in my fuel and run it for a while to keep the soft goods from drying out if it's goin to sit idle over a long period of time , Shelf life for gasoline is not great but one season to another has never given me problems
I do not endorse or am a fan of fuel stabilizer either. The product often states, “will keep fuel good for up to two years.” That may be true if you have a sealed and never opened container such as True Fuel aka canned gas for $20 + dollars a gallon.
Hello B.,
I like Marvel Mystery oil, and it has been a proven product for many years. It started out as a carburetor treatment way before any of the other modern "snake oil" product came into existence. It is actually a "Stoddard solvent" product which melts down carbon and gum deposits. Many people have never read the actual product history and formulation to understand it.
I agree Tiger,
That is where marketing misleads many people. A sealed container such as a 1-gallon steel fuel can does not get oxygen in it. With plastic fuel cans/jugs all bets are off.
After about 30-60 days, the lighter and more volatile fuel is lost or greatly reduced in a normal gas tank. These lighter fuels are responsible for the pop or kick needed to start an engine. These lighter fuels are more important the smaller the engine is. That is why fresh fuel in a 2-stroke chainsaw is even more important that a twin cylinder 4-stroke 27 horsepower engine.
