Does anyone have a current repair manual link for the KT735 series engines?
Auto Doc's
I have a Kohler PT-KT735-3077 engine that I am getting ready to put a set of new factory heads on and would like the most current engine repair information if anyone has it in the library or links available. I've check mine and do not have it. The heads will not likely be here until next week.
Any help is appreciated.
Why are you replacing the heads?
Hello H.,
Valve springs collapsed, rocker studs backing out and both intake valves very badly stuck in guides due to suspected bad/contaminated fuel being used.
The part numbers for the heads have had 3 different revisions. I figured that I am better off going with the Rehlko/Kohler head kits that have the heads with valves installed already along with gaskets pushrods, rockers and hardware.
The instruction paper in the kit only has the head bolt torque and sequence.
I also have a fairly good library though being authorized to access Kolher dealer site I update to the '26 from the '22 version.
I also been pulling all my manuals off Goggle drive since I was getting requests for edit access. Not suppose to have any access other the share directory. Now I got a 2TB external drive that I can put in my shirt pocket but I still keep a copy all SM files on the local HD too.
Just remember to do a 3 step torquing.
