John Deere RV43RVE part question
First, I think your model number is incorrect, could it be R43RVE. Second, are you outside the US, I ask this because I’m not find your unit in US distributors? Third, where on the unit is the part attached? Unless I can understand your unit better, I can’t be of much help. Sorry about that.
Coming up as an electric mower on searches.
But need a Picture of the serial number tag please. It appears to be a rear wheel cover. need to search serial/pin number.
Okay as suspected it is a cover for the roller drive. You have a R43RVE SA816 or SA916 model. LH covers the chain and RH is just for a finish look.
LH cover PN SAA10241
RH cover PN SAA10242
Unable to find any image of either part.
R43RVE SA816 and SA916 IPLs
Funny if you enter the serial it comes with a different R43 but using the R43RVEand selecting the SA816 then you get to right mower.
After looking at the pics I googled JD ROLLER DRIVE MOWERS and then found R54RBK which then gave those exact numbers. Two ways of getting to the same answers.
