Illini Pete
Hey Y'all, new to this forum but not new to Cub Cadets. My problem is with an LT1050, probably around 20+ years old, hadn't run for 4 or 5 years, so wanted to get her back on the yard. New battery and new starter solenoid and when I went to hook up the neg battery cable, got a spark, with key off. Pulled ignition switch and checked all poles with key in all positions and all checked out OK. Cleaned all socket plugs I could get at and still have a circuit open somewhere. Removed cable attached to starter and no longer a spark when I touched neg ground cable to neg battery terminal. Removed starter motor and bench tested it and all worked fine. Any suggestions on how to proceed?
Thanks!
Illini Pete
Thanks!
Illini Pete
