Chazzy-Chas
Only has one blade, I believe am at full throttle.Did you level the deck by using the blade tips or deck shell? Did use an OEM belt? John Deere tractors are very fussy. Is the center blade turning as fast as the outside blades? Will need an assistant to help with this. Are you mowing at full engine speed? All these can contribute to the problem.
Read my reply to MParr
Thanks for all the good thoughts.
