MikeinTassie
Hi Bertrrr, I do realize that and have been very careful to do it right with the install. Even replaced the diaphram, just doesn't make sense!If you're choking it to make it run, it's starving for fuel , you still have a fuel problem with the carb or fuel pump diaphram
Hi Bertrrr, I do realize that and have been very careful to do it right with the install. Even replaced the diaphragm, just doesn't make sense!
