A lot of "grey stuff" in the oil pan. I suppose that was the remaings of the cam lobe.....Clean the inside of the crankcase but most of the metal shavings will be in the oil pan be sure and clean it good.
Talk about worn camshaft lobes! That is ridiculous. As you said, how did the engine even run?Some feeedback. You were right.
Its a miracle that it worked at all. Almost round.
But what surprised me was that it looked as if the engine had ben opened before. I thought this engine was "sealed for life". I do of course not know what was done but i must have been for a good purpose. Are camshafts typical weak components?
That double jump on the lower valve is a classic sign of a sticking valve or a worn cam lobe. Given the sudden power loss, I'd bet on a valve not sealing. Check your lash and look for carbon buildup. This guide explains how valve issues cause power loss: https://wildwoodsmallenginerepair.com/small-engine-valve-adjustment/Hi
from one day to next day, the power was dramatically reduced. Something broken i guess, not just getting "old".
I have checked the spring on the governer and the valve clearance without result.
But when looking at how the valves move when turning the engine I might have something.
The upper valve (exhaust i guess) move as expected.
The lower valve moves less and has a "dubble jump.
Damaged camshaft?
Any ideas or suggestion what to check?
Before I adjusted the lash, it was slightly to big. Then I reduced it a bit, but no big difference in result.That double jump on the lower valve is a classic sign of a sticking valve or a worn cam lobe. Given the sudden power loss, I'd bet on a valve not sealing. Check your lash and look for carbon buildup. This guide explains how valve issues cause power loss: https://wildwoodsmallenginerepair.com/small-engine-valve-adjustment/
Make sure you de-carbon the entire block when you have her laid open on the table.Before I adjusted the lash, it was slightly to big. Then I reduced it a bit, but no big difference in result.
Both cam lobes in poor condition, The inlet REAL bad!!!
Now I have ordered a new camshat and will also replace the tappets.
Lets hope the valves themselves are not bad.
Thanks.....it DID make me a bit worried.....OIl pump driver. some motors use a supplemental oil pump which is driven by the cam. if you don't have an oil filter or provision for an oil filter on the side of the oil pan, then that part is not used.
