10 year old Cub cadet Proz 900. with a ecv880-3013 motor, 265hrs. I took this to the dealer I bought it from and they could not get it running. $1500 and they said buy a new one. This was New Holland of Tulsa.
This is what is doing. Will not fire up. It has spark at all the plugs, New coils, New fuel pump, new injectors, Has fuel ejecting from the injectors when cranked. Even tried starter fluid and still got no combustion. The dealer said the engine has good compression. All the dealer did was start replacing parts and still could not get it running. The sad part is when I took it in it was running, just not very well.
The service manual says check for trouble codes, This model has a small digital display right below the key. It is flashing "Lube now", now this is what is even stranger, I disconnected the battery and the display is still flashing. reconnected the battery, I tried to do the code process, the on and off with the key and got no difference on the display. Is this the MIL display or do I need to do the LED trick to find the diagnostic codes?
This motor will produce spark, has compression and has fuel but will not start, could this be something with the ECU or the timing. Can timing be off so much where you have all the right components but still not starting.
Any help is what direction I should look next would be appreciated.
