slimshady69
- Jun 19, 2024
- 24
It doesn’t looked drilled out to me. Anyway, you will need to drill it out slowly and carefully and keep stepping up on drill bit sizes. If you have left handed drill bits that might do it when you get close to bolt being drilled out.I broke the bolt that holds the rear tire , I drilled it using an extractor kit but it wont budge,need info on what to do next
Didn't workIt doesn’t looked drilled out to me. Anyway, you will need to drill it out slowly and carefully and keep stepping up on drill bit sizes. If you have left handed drill bits that might do it when you get close to bolt being drilled out.
Ok I tried the easy out didn't workScrew used was a 5/16-24 x 3/4 [710-05339A].
Next sizes are 3/8-16, 3/8-24, M9-1.00, and M9-1.25. The 3/8-16 and both M9s uses a 5/16 starter hole. The 3/8-24 use a Q bit which is slightly larger than 5/16.
If the OP breaks off a ease out he will need to switch to carbide bit to remove it. These bits don't sudden stops and will break.
