Hustler SD transaxle leaking oil...is there a fix?
Saint Francis
My transaxles began leaking from what appears to be from where the disengage lever goes in... I think 🤔 That said, are they serviceable?
Whenever you ask about a machine, you need to include the chassis ID label information. If it involves the engine, it will have its own label that we would need the information off of.
Is it a running leak or just seepage with dust gathered around it? The main thing is to keep them topped off before a major internal failure happens
Yes are serviceable but you have to remove them to access the area.
On the transaxle axle housing should be the Hydro Gear model number that is needed to look up parts.
Thank you. So there's hope. Do you know where to order from. Do I need to go to Hustler for this?
IF you have the HG PNs then any Hydro Gear dealer can sell you parts. But I would need that number off the axle to even look up the numbers. Just some seal may require a full seal kit.
With that model number I can send you an IPL thru a backdoor as I am not allow to publish then openly.
Thank you. I can't get to it till later this week but will do so.
