Hoping someone out there can help me get back to cutting my grass.
I have just replaced the starter motor and starter solenoid on my ride on mower complete with a new battery. When i switch on the ignition the light comes on the when i start the engine nothing happens. Keeping the switch fully 'on' the ignition light begins to flash 'on' and 'off' until i release the key back to 'ignition on' the the light is constantly lit until i switch 'ignition off'
I have checked the voltage across the starter solenoid actuating coil when attempting to start the engine but this shows zero volts. the motor turns over when i short across the starter solenoid main terminals(not the actuating coil) . Hope this makes sense.
Any ideas wold be gratefully accepted.
Thanks
Jeff
Thanks
Jeff
