- Sep 7, 2024
- 3,489
I run Royal Purple 20W-50 in my '95 Harley and it is a vast power improvement over the SAE 50 Harley oil they were recommending. Straight SAE 50 is way outdated in my opinion.
Air cooled engines are critical about the correct viscosity for the ambient temperature conditions. The most wear on any air-cooled engine is in the first couple of minutes during initial warmup. That is where multi-weight oils work the best.
For rider equipment I use STP 10W-30 most of the time and make sure the level is maintained especially in hotter climates and prolonged run times.
Anyone who thinks an air-cooled engine does not burn a little bit of oil is sadly mistaken or too cheap to keep extra oil at the ready when needed.
I am not a fan of the older straight weight oils. They were developed for the times. Oil technology has improved many times since those oils were prescribed in the service manuals years ago.
Factory oil recommendations were not "written in stone"; they were written on paper.
