That is the same plugs that I use because they are readily available. I really do not like CHAMPION plugs but they last a long time in the opposed twins. If you ever run into a opposed twin that will not start up when the engine is hot and you install new plugs and it's ok for awhile and does same thing again after it's run awhile, it;s a weak magneto.
You are close enough on the rpms. The specs are in the service manual and the high rpm is easily adjustable on a big screw on the throttle plate. Sometimes that screw over several hours will vibrate to a lower rpm and green or blue thread lock will secure such. (FIRST make sure the STATIC governor is correct if you have issues with high rpms) You want to keep the engine speed at high rpms when mowing, max air across the engine. Install a pre-foam air filter and your main air filter will last longer. (and keep the fins clean. I use a leaf blower or air compressor and clean the engine often if mowing in dirt or lots of dead grass. Clogged fins will result in valve seats coming out.
If you ever have a valve seat pop out contact me and I have a easy permanent fix for such.
Better than trying to do the staking.
Another thing you will notice on the opposed twins that is mis-leading when troubleshooting is when one is cranking fast and not starting (due to ignition issues) and it's getting gas you WILL SEE the carb spitting gas up out of the carb throat making you think a intake valve is not seating. I've seen guys pull the heads looking for bad valves due to seeing such.
It's normal. If you want to see such just kill the ignition and look into the carb throat when it's cranking. You will be surprised if you have never noticed such before. If you give it a squirt of gas as a prime it will spit some back up out of the carb throat when it's cranking fast. (It's the intake valves momentarily doing the compression release)
