- May 6, 2010
- 12,021
The bottom push rod is aluminum and the top one is steel Unless the aluminum push rod has a groove worn into that shiny area I would just flip it over and put the shiny side down inside the pushrod cavity. And have you checked the oil level and make sure it also isn't full of gas. Hydrolocked cylinder most likely also filled the crankcase with gas.
