Bmwz3coupe
- May 28, 2022
- 42
I have a briggs based self-propelled walk behind mower that when you start the engine it just goes putt......putt......putt......putt......putt for up to 15-20 seconds before it dies. I can start it up again and does the same bearly running thing. Throughly cleaned the carb twice and new plug and the flywheel key is in correct location. 95 psi compression.
