So a few nights ago I was merely cutting the lawn and then all of a sudden the engine just quit. So I decided to take off the valve cover, and pretty much found all this stuff. Not positive I think the rest of the engine's okay. I have bent push rods before this is the first time ever broke the rocker arm stud. The only thing I found that I thought was unusual is the stud for the rocker arm It requires a 10 mm deep socket and I think the torque is around 10 ft lb I was under the impression it was a 3/8 in deep socket but that socket was too small. I couldn't find where the size is printed but it seems it would have to be a 7/16 in deep socket that would work.
Does anyone know if this is 10 mm for the actual hex nut?
Thanks,
Jim
