- Sep 7, 2024
- 3,475
Sounds like your fuel tank needs to be removed and washed out really well then left out in the sun to dry before reinstalling.
Go back to the OEM carb. You've established that the carb wasn't the issue. This new issue might be due to the aftermarket carb.Yes, I did clean the tank. That old Craftsman had never had the body lifted off...lots of rusty bolts. About my latest issue of hitting a bump and cutting out/loose connection...I tried the seat switch, checked all connectors on harness, die electric greased, grounds are tight, no bare wire found. Any suggestions ?
Not recommended but it's your mower.I bypassed the seat switch,
For what exactly?checked all connectors on harness
Ummm, Ummm, dirt, grass and grit sticks and collects to greases and oils. Again your mower but clean and tight is best.die electric greased,
Tight is part of the recipe. How about clean and corrosion free? Clean to bare metal polished with Flitz Metal Polish? Use some star grounding washers.......grounds are tight
Take an INSULATED small stick of some kind. Something you won't get shocked with. Tap all around every wire AND connection on the mower. See if she stumbles or tries to die.Any suggestions ?
Look for drag marks ON the fuse legs too. No drag marks = a loose connection creating high resistance pulling extra unwanted amperage.Next is the main fuse holder and fuse. Pull the fuse and see if appears like it's beginning to melt the plastic.
