TiIngot
- Sep 9, 2022
- 55
This is probably not new news to many here. I hit an object that broke a deck spindle on a Craftsman T-240 46” mower. After the removing the original broken OEM spindle, the guts basically fell out of it.
It had a grease fitting built into the spindle but from the factory, no grease was inside the spindle and it had sealed bearings. The new replacement also had a grease fitting built into it and I pumped and pumped grease into it and gave up trying to fully fill the cavity.
I just don’t understand the logic of putting in a grease fitting built into the spindle and not adding grease from the factory.
