I edited my comment. I gave you two alternatives.Just found that, thanks. Is there a good way to pick an equivalent? Lots out there for 1/2 the cost of Hydro-Gear. Normally on Amazon, I look for lots of good ratings, and stay away from stuff with only a couple reviews.
This video is of a Scag. The Dixie Chopper will be similar.There is a tab or lever on the back of the transmissions. When disengaged, the mower will not move. When engaged, the mower will move. Make sure both are disengaged before starting the purge. I would disengage both before jacking up the mower.Ok, last question for today. How do I activate the bypass? The hydrogear manual shows where the bypass levers are, but I don't recall anything on the Dixie Chopper to activate them. The manual says I need to cycle the controls with bypass open and closed. I've ordered filters, and hope to do this Saturday.
