Starting Issue
awatley41
First time zero turn mower owner. husqvarna rz4219, hand me down from my father-in-law. currently has a starting issue. checked valve lash (.004 int &.006 exh). intake valve does that little jump, so i think camshaft is good. sparkplug looks fine. battery was hooked up to my car battery (car not on) while trying to turn over. not sure what the problem is. i dont believe any safety switches are the problem. goes through 1 rev and stops. any suggestions?
Could be hydro locked. The needle valve and seat in the carb may be not closing and letting fuel from the tank drain into the crankcase. Drain the oil and see how much comes out. If way more than normal, and it smells like gas, you’ve found the problem.
I had a problem with my Husky CTH1736 losing fuel when parked up for a couple weeks, when i did start it it smoked badly, couldn't see any fuel leaks so put a shutoff valve between the fuel tank outlet pipe and fuel filter and now don't lose any fuel when parked up, when i first bought the mower secondhand the oil level was very high so presumed it was leaking fuel into the cylinders, bought the fuel shutoff valve from Ali Express for $2, will post a photo later soon.
It's a good idea to change the oil, if fuel has been leaking into it. Watch out for cheap shutoffs, some need to flow one direction, and it's not always marked. They can also start leaking, so keep that in mind. I just had to replace one of mine for leaking.
