Propflux01
Why won't this fit a FR600V? Is the intake horn smaller or something?
yes, it will work on the FS/FR600v. you need an adaptor to go from 1.75 on the intake tube to the 2.0 ID of the intake hose. PN Gates 26392Why won't this fit a FR600V? Is the intake horn smaller or something?
Here are a list of parts that will work for the kawasaki.Hey has anyone ever tried the
DVPARTS Heavy Duty Style Canister Air Filter Kit, like the ones they sell on Amazon ? How is the quality?
Been trying to find one to upgrade my gravely XTHD 52” , they have a lot on their pages don’t know the difference in them?
Thanks
I installed this kit on my relative’s Hustler’s FR691. Fit was perfect. If I have this engine, I would install this kit for engine longevity.They are out of stock on their website![]()
They are in stock as of July 8th.They are out of stock on their website![]()
Bought this bracket from @kipharding mentioned here. Worked great. Shipped quick and looks good. If you're looking to build the kit yourself I can vouch for this mount.Here are a list of parts that will work for the kawasaki.
FR/FS series
You will need a G057512 or equivalent canister filter I have found as low as $32
G057512 canister filter links to several incase they are sold out
https://amzn.to/4g4zSl5
https://amzn.to/4e9xGGq
https://amzn.to/4vxI55Q
Rain cap found this one for $14
https://amzn.to/4odWhi8
https://amzn.to/3RJorpb
The hose I used is a gates 21943 look online or local auto parts store. I found one for $18
If you can not find it than a dayco 71503 will work
Hose clamps for a 2 inch hose and hose clamps for the filter housing 6in
$50 shipped for the bracket I sell these they are similar to the ones in the kits. If you have a FS series I will throw in the riv nuts and screws for free
FS series extra parts
Well nuts
https://a.co/d/05fI8hBR
Screws
https://a.co/d/0dteelpg
If you have any questions or want to order a bracket email me at [email protected]. I'd be more than happy to help with installs or any questions.
The bracket for the kawasaki will fit...
FR651V FS651V
FR691V FS691V
FR730V FS730V
FR600V FS600V
New and old style filter cover
How do you get the lid up enough to undo the clamp if you need to remove the hose for some reason? Also, with the hose being that tight in it, aren't you worried that vibration will start cutting into that hose?Bought this bracket from @kipharding mentioned here. Worked great. Shipped quick and looks good. If you're looking to build the kit yourself I can vouch for this mount.
All the parts listed here work well together. I got the gates hose from rock auto for about $20 shipped, the rest was from amazon. Total was about $120 and took maybe 30 minutes to install including cutting the hole in the cover (which you don't have to do; you can leave the cover off. I just like the finished look).
It lifts enough to get to the hose clamp pretty easily. I do plan to trim the cover more to have it fit better. I noticed that as well.How do you get the lid up enough to undo the clamp if you need to remove the hose for some reason? Also, with the hose being that tight in it, aren't you worried that vibration will start cutting into that hose?
I bought a new one for about $10:00 and kept the one that come on it if I had to take in for service,warranty also cut the hole looks betterIt lifts enough to get to the hose clamp pretty easily. I do plan to trim the cover more to have it fit better. I noticed that as well.
