GT2200 Drive Belt replacement
Just picked this up, drive belt broke, not sure it is still on the machine, but I am in need of routing diagram. Also there are a couple different methods of getting the belt on the drive pulley.
The one requires removal of the electric PTO clutch and then sliding the drive pulley down below the guides. Most of the time removing these can be a bit of a challenge. The other method involves removak of the motor mounting bolts, usually 4 and then you can slide the motor around enough that you can route the belt around the drive pulley then reinstall the mounting bolts. Still no picnic.
Any other suggestion before I start tearng the hide off the back of my hands and wrists?
