GearHead36
- Apr 26, 2023
- 456
A few years ago, I bought a well used ZTR with a Confidant EZT750, a twin cylinder 27HP engine with EFI. IMO, that was the worst part of the mower. The mower had all of the features I was looking for (fabricated deck, serviceable hydros, etc), but it had that #%#@%% EFI. I know how to fix carbs. Not so much with EFI. Since the engine seemed to run well, I bought it.
When I bought it, it needed several repairs. I did the minimum amount of repairs to get it into service, with plans to do a more complete service in the off season. That first season, on several occasions, when cutting tall and/or thick grass on hot days, the mower would lose power, and start belching black smoke. I thought maybe a belt was slipping under heavy loads. I'd hit the PTO switch (disengaging the blades), lower the RPMs, and it would start running smoothly again. I'd continue mowing, and it might do that again, or it might not.
In the following off season, I discovered that the cooling fins were almost completely clogged with oily dirt. I was amazed that the engine hadn't burned up. At this point, I had the engine out of the mower, so I did a thorough cleaning with a pressure washer. It ran well for about another 1.5 seasons, so I thought I'd dodged a bullet. After 1.5 seasons, it died when the camshaft gear disintegrated, I'm betting from running hot. While repairing this, I did a few other things to it, like replacing the head gaskets and main seal. I referred to the shop manual numerous times. One time, I noticed that this engine has an engine temp sensor. Hmmm. Thinking back to those times of power loss and black smoke... I'm sure now that it was the EFI system putting the engine in a "limp home" mode to save the engine.
So it's likely that the only reason that this engine is not a paperweight is the EFI system.
Now I DO like:
- It runs perfectly at any air and engine temperature, and any altitude. No worries about the AFR being rich or lean.
- When the engine is shut off, fuel delivery is immediately shut off. So there's zero risk of the crankcase filling with gas due to a leaky needle valve, and zero need for a fuel shutoff valve and shutoff solenoid.
- No choke, so no need to learn the 'personality" of the engine, and how much choke it wants. I have an older single cylinder Command Pro, and it definitely has a personality. And a fuel shutoff valve.
- Low carbon buildup in the combustion chambers.
- Better fuel economy. It has two 3.5 gal gas tanks. I can get about 8 hrs of running out of that, which is good for a 27HP engine.
- It's very easy to use. Easy enough for my wife, who mows the grass now with this machine.
What I don't like:
- It has a bunch of sensors. A failure in any of them would likely prevent the engine from running.
- I have no way of determining if a sensor is good or bad.
- If the EFI system has a problem, I'll be paying dealer shop rates and parts prices to get it fixed.
- A gummed up fuel system is WAY more problematic than a gummed up carb. This is not much of a concern in my case. It's my primary mower, and I always use E0.
#$%^@# I don't WANT to like EFI on OPE engines, but I have to admit, it most likely saved this one. Still... if I ever have to replace it, I'll likely go with something with a carb.
Does anyone prefer EFI over carbs?. I'm talking about an engine that runs well. Not one that needs repairing. How many would pass on a mower with a good running EFI engine?
Now I DO like:
What I don't like:
