750F is not high for an exhaust under load, but melting steel as you described is. Personally, I do not know of any epoxy that will maintain strength at the temperature you need it to. Add to that, it has to maintain bonding on a deteriorated surface that vibrates, and expands and contracts too. Last time I checked, a tube of High Temp JB weld lists 550F as the top sustained temperature - and is around $9. A couple tubes would buy a new muffler. The metal paste is listed to 1000F but it is not an epoxy. There are some companieslike JB Weld that use sodium silicate as a bonding agent at high temp. It doesn't tolerate vibration well. or moisture. Pepboys used to sell it 50 years ago to patch mufflers. Sometimes it would come with a fiberglass patch. Never worked for me because the surface it had to adhere to was already compromised. That said, I was not wanting to get into that debate but rather just shed light on why a standard non-catalytic exhaust system might overheat, in hopes of preventing it from happening again, or if a year from now someone is reading this thread looking for a solution to why their exhaust is glowing bright cherry red. I am of the opinion that the cost of the sodium silicate would be better put on a new muffler. I hope your fix lasts a long time. Keep it dry.
