Just making sure....
Okay are you leaving both kill wires attach to coils? I know you said you disconnected the kill wire but could have done somewhere else. If so the coil that firing can be the one that is bad.
Otherwise there is no way a short in the harness would be killing the coil as it would be isolated from the harness.
