Your engine, do as you wish. I would say wrong.
In hindsight, yeah, I was wrong. I should have cleaned the fins during the initial repairs.
Yeah, not buying it. One person could have that entire engine off the mower in under an hour with common hand tools. What 4 bolts, couple belts maybe one or two harnesses and a choke/throttle cable? What did I miss?
Roll bar. Bumper. PTO clutch. Fuel line. Starter cables. Muffler shield. Weight of the engine. It's a 750cc V-twin with EFI. It's NOT light. I can lift the engine straight up off a dolly, but if it's in the engine bay, I'd have to lean over it to lift it. My back won't let me do that, so I have to rig up a lift or hoist of some type.
Reinstalling the engine... there is an "Engine Shield Plate", that sits under the engine and on top of the engine mount plate. It has to be lined up to get the engine mount bolts through. Every time you slide the engine to line up a mount hole, this shield plate moves too. I discovered this time that it's supposed to have a couple of plastic push pins to keep it in position, and they were missing. I found a couple, and installed them, so now when I slide the engine around, the shield plate doesn't move. Getting the engine lined up, and mounted was MUCH easier this time.
I'm a gearhead, and I know my way around wrenches, but I admit, I'm no small engine expert. I'm sure many others here could do the job in an hour, but I don't think your average shadetree mechanic could do it that fast. I have another ZTR with a single cyl engine, no roll bar, and no bumper. I could likely get that engine out in an hour.
The roll bar and bumper are nice features to have, but they interfere with many things. In putting the engine back together, I messed up the RTV on one valve cover, and it was leaking oil. The roll bar had to come off to get the valve cover off.
Really, you shouldn't have to remove the engine to clean the fins. Since I had to take out the engine again this year, I had no problem accessing the fins. I pressure washed the whole engine. Next off season, I'm going to try something else. I'm going to remove the main shroud (the one on the top of the engine), and see if that will let me get to the fins with a pressure washer.
