Is this another Briggs autochoke?I have an older Toro Recycler mower the is tough to start when cold. Sometimes I try a dozen pulls, then I squirt some gasoline into the carburetor and it starts. Is there any way to add a primer into the engine for cold starts?
Model 2038 SN 314011203Please post your units model and serial numbers so we have an idea of what engine you have. That way we can advise you on how to proceed without guessing.
My bad. It should be model 20381You are missed thhe last number in the madel. I’m assuming you have a Honda engine so there are two things I would check. First check to see if the choke is fully closed at start up. If it is closing fully I would be cleaning and rebuilding the carb, making sure the the float level is set properly.
