End_of_Rope
- May 12, 2026
- 4
Ignition coils - that is longshot considering the plugs actually look good indicating good combustion. The engine is running clean with a lean surge. I am getting to the opinion of too much air instead of not enough gas.You have a timed running issue. Check the fuel tank. Should flow like a new one with zero trash in the bottom and in the outlet nipple. Flow test it with some Diesel into a glass jar. Not as flammable as gasoline.
Long shot is a failing ignition coil but 5-6 hours later??? Wouldn't your gas tank/s be dry by then?
As to fuel spouts, I don't use them. I pour gas direct from the container thru a filtered funnel.
