jerrycmorrow
- Mar 16, 2014
- 88
Have a john deere js30 mower. Purchased a craftsman/briggs&stratton 190cc. 8.5 ft-lbs engine (2017) from BrandNewEngines and after it sitting around in weatherproof storage for about 6 months i installed it this spring.
Used it 3 times on a large yard with good amount of rocks and it ran perfectly. The last time using it the blade kissed a buried rock and mower died. Havent been able to get it started since.
This is what ive done so far:
1 - checked spark with in line tester. No spark. Checked tester on known good mower - great spark.
2. - pulled flywheel to check if the flywheel had slipped on the crank. The flywheel is perfectly aligned with the keyway. The key is straight with no indication of torque damage
3. - checked valves for opening/closing. No seen issues. Didnt check valves against TDC; probly should
4. - pulled magneto to check resistance
Primary windings are 1.8 ohms (0.4 - 1.5 spec’d)
Secondary is 10k (2.5k - 15k spec’d)
5.- kill wire shows 0 ohms
6. - plug wire resistance from plug connector to magneto is 0 ohms
7. - reinstalled magneto after cleaning it and where mounts on engine - no spark
8. - tested and replaced spark plug with new plug
9. - tested compression - 95 psi ( note this is a new off the shelf engine so is probly not broken in)
10.- checked spark - no spark
Only other thing i can imagine is the crank twisted inside the crank case. Gonna check valve timing against TDC
anyone got anything? Thanks for any help. Jerry
