right tools for the job
Here is a good video showing another light bulb coil tester that is no good. Open gap type clearly shows proper coil condition at low to high revs. Chalk up another win for the PET-4000.
Starts at 6:40 into the video.
It's my opinion that rubber gloves aren't a good alternative to proper mechanic's gloves.
Not to mention using a worthless spark tester. Adjustable air gap testers are more expensive, but if one wants something that works, bite the bullet and buy it. Cheap tools only make your job harder.
If you can swing $1.35......
Yes it works, just bought another one a week ago.
To remove excessive sealant on valve covers: Use a heat gun to soften the sealant, then a couple of small screwdrivers to gently pry valve cover. Then use a wire wheel on a battery drill to remove sealant from valve cover and cylinder head. Scotch bright and carburetor cleaner for the last bits of sealant.
Best way to get the valve cover off is to take a 2x4 put it up to the side of the valve cover and hit it with a BFH. May have to hit both sides of the valve cover but it comes off and you don't bend the valve cover like when you try to pry it off
Bingo! Give the guy a six pack of drinks. Soft drinks or otherwise.
5n1 tool or putty knife is a whole lot easier. Will not distort the cover compared to a brute force attack.
Apparently you haven't ever tried the board and hammer method. I use it on Briggs rocker covers all the time here without damage. I even have removed a few Honda covers. That's what the board is for, it spread the force across the whole side of the cover.
No I haven't. Why? Because I OWN my equipment and want them to last. I'm not a shop where time is money cutting corners. Always three ways to skin a cat I get it.
We want to break the seal not the part.
