MTD sprayer
I am converting an old MTD/WHITE ride-on mower into a small (mobile) sprayer unit.
The front wheel bearings on this mower are ball bearing type where the inner race (reasonably thinking) should not be turning on the axle, but held firmly.
This is not possible due to the wheels held on only by washers and split pin.
These inners have been spinning on the axles causing wear.
Does anyone have a fix for this that does not involve glueing the inner to the axles which would compromise pulling the wheels for tyre changes?
Thinking that contact cement might hold enough to prevent slipping or, an old idea, of roughing the axles by multple centre punching of the axle surfaces?
