Psychopete
- Apr 14, 2026
- 7
I had this thing setting for like 5 years, I used to push, my g/f kept telling me to fix it and use it; but this did not make my life easier.
OEM deck belt part number is 1716854SM. Looks like it should measure 90.4"The guides can breathe, but the belt is seemly weird when it comes to finding one - does anyone have a part number they recommend? I tried a random 89" that was "on always" and it smoked it. I will pull the deck out again and fine tooth comb over. There's a reason things are free, right? Someone else couldn't figure it out =/ Am I to make sure the fence style guides are perfectly 90 degrees?
What should I be looking for(?) I have replaced all deck bearings, but this thing seems to go through a belt about every 2 months. If there is a procedure that you have in a manual, or something to that affect; I am mechanically inclined - I am poking minds, as someone will probably know what it is. I don't work on these machines all day; and I think I am missing something very obvious. Thank you for any insights you may have.
Edit: it's a 38" deck, package 2690321, mfg 1694688, serial 02210
www.partstree.com
And THERE'S YOUR DINNER. Taryl described the same conditions.What should I be looking for(?) I have replaced all deck bearings, but this thing seems to go through a belt about every 2 months.
Mower freaks call it love.I have had this thing all apart; you do know what it means to replace the drive belt on these I assume (?)
Everything on a mower deck has to be just right for it to operate correctly. A deck belt should literally last for several years if things are correct.The guides can breathe, but the belt is seemly weird when it comes to finding one - does anyone have a part number they recommend? I tried a random 89" that was "on always" and it smoked it. I will pull the deck out again and fine tooth comb over. There's a reason things are free, right? Someone else couldn't figure it out =/ Am I to make sure the fence style guides are perfectly 90 degrees?
I just had to give up on a mower I was going to sell because I couldn’t get the deck right after several hours of attempts.
A customer this week just traded his riding mower and cash for another mower I had for sale. The deck was missing several parts that another shop had given an estimate on and the customer declined. I ended up looking at it with no good back story. Customer didn’t even know he was missing an idler pulley among other parts missing.
I have a Gravely MZT1534 that would shred belts every few months. When I would engage the electric clutch I could hear the belt squeal and smell a puff of smoke. I started only engaging the belt at idle speed and this has increased my belt life.What should I be looking for(?) I have replaced all deck bearings, but this thing seems to go through a belt about every 2 months. If there is a procedure that you have in a manual, or something to that affect; I am mechanically inclined - I am poking minds, as someone will probably know what it is. I don't work on these machines all day; and I think I am missing something very obvious. Thank you for any insights you may have.
