doc craker
- Apr 1, 2026
- 19
ok. fairly certain I have located the proper tool.
on the way. Be here tommorrow.
thanks
thanks
ok auto doc's.
all I have is the bulb type. You attach it to the plug and then the plug wire. Not reliable?
OK . I will order the other one. Do happen to have a link or good description of the tester?
One of those FLIR infra red cameras was exactly what you needed to SHOW you which one was or was not firing. Perfect tool for the job.One of the cylinders is not firing. Hard to believe that a 2 cylinder engine would still run smooth after dropping a cylinder.
No not accurate is a better word. An open gap style, one can make the gap larger or smaller to stress out the coil. Also testing while running, you will see low revs might be ok. Then possibly fail at mid and high revs, coil giving up the beans.ok auto doc's.
OK .
www.hipastore.com
I use the spark tester that lights up with orange light all the time. I also have the other type that jumps the gap.One of those FLIR infra red cameras was exactly what you needed to SHOW you which one was or was not firing. Perfect tool for the job.
Throw the Christmas bulb type tester in the trash. Doesn't take hardly any spark energy to light off one of those bulbs. It doesn't stress out the coil confirming strong spark.
This is what you need. I just picked up another one off fleabay for like 2 bucks shipped. The best one is a PET-4000. Cadillac top of the line testing tool.
Quick & Simple Way to Check for Ignition Spark Using An Adjustable Spa
The ignition spark tester provides an easy way to eliminate the ignition coil as a cause of problems when you're having a no-start with no fire situation. You can download a PDF manual for repeatedly check.www.hipastore.com
In Line Spark Plug Tester High Energy Ignition Coil Engine Auto Diagnostic Tool | eBay
Advantage of ignition spark tester: Determine the quality of the coil based on the color of the sparks and the flashes in the distance Intuitive and easy to understand the operation of the ignition coil Alligator clip securely fixed to the ground Screw assembly allows quick and easy adjustment...www.ebay.com
Thanks slomo. If the one side is too close will it prevent it from producing spark?Most are 0.008" but check YOUR engine manual for proper specs.
No.Thanks slomo. If the one side is too close will it prevent it from producing spark?
