I may now have the answer, However, I do not yet know. ..........I am doing a repower with a brand new Briggs engine. When I wired the battery the lights came on. The key was off. Engine off. If I unplugged the 2 ignition switch connectors the lights stayed on. When I unplug the red charging wire they go off. Some how power is going to the light circuit through the red charging wire. I was told by the salesman this should be plug and play with my Bronco and this engine. There are 4 wires in the 6 pin connector. Red, Grey, Black, Orange. I believe the Orange is for an accessory. Grey is DC for the carb solenoid. Black is ground. Red is the charging wire putting out dc to the battery. My understanding is the lights run off AC? NO? I noticed on the new engine the red wire coming from the regulator is jumped to the orange wire. I am suspicious the Orange may feed be feeding the lights. The light wires are green and blue. I can not follow them completely but they do appear to go to both connectors on the ignition switch. The lights are suppose to be on when the engine is running. Maybe also key on engine off. I am not sure because I never saw this machine run. My thought is I need to cap off the orange wire. The lights will run only from the Engine and be isolated from the battery. I do not have much experince with tractor electrical stuff. What do you experts think.??? I know, if I had a wiring diagram I could figure it out. But they are not made available to the public any longer. You need to be an MTD dealer from what I have been reading.Hello N.,
What kind of electrical problem are you having? Diagrams can be difficult to find. This model had fairly simple wiring.
I assume that is the case. I got it with a blown engine.It appears that your new replacement engine has a different charging stator. This is a 2023 model and already needs and engine?
Sounds like oil was never checked since new.
thanks. I don't have the old stator. You are right the new engine has a rectifier/regulator. IT sure appears the only AC wire from the Stator goes right into the rectifier. No other wire but ground. So all power is DC? right?The diagram is a little light with the printing, but it can be followed if enlarged to 25% and each wire followed carefully. This shows to operate the headlights through the start switch assembly.
Yes, the headlights work off of a split circuit stator that supplies the AC current. They are powered by a blue wire off of the stator chassis to engine connector on the original engine.
The original engine likely had an inline charging diode wire, and the replacement engine has an actual 12V rectifier/ regulator. They are different charging systems.
The flywheel needs to be removed, and the stator installed from the original engine from the sound of this situation.
