Kawasaki Parts Diagram
lefty2cox
I gots me a Kawasaki FS541V-BS14 engine for which I'm trying to find a parts list. From what I gather, the model seems to be particular to John Deere Tractors. I'm struggling to match the spec number online. It jumps from BS13 to BS15. How important is the spec number? Should I just go with the closest?
Thank you.
Thank you. I can get the main page with the diagrams but can't click on them to view. "Wrong selected catalog! Please start again!" Could it be a permissions thing?
I'm trying to see the crankcase diagram. Looking for the part number for the governor shaft seal.
Oh the Pita of an oil seal to change without opening the engine.
That seal is a common item.
And I should had remember that I can't go thru the back door to the site. I had that problem a couple years ago. But is where find 95% of JD Kaw IPLs with Kawasaki PNs instead JD PNs so you can pay less. And I don't mind sticking it the bunch of jerks here.
So let's try the side door. This link should work. Just remember to confirm the cookies and privacy policy.
https://parts.kawasaki.eu/kepcc/kepcc?ALIAS=99253
You will have to navigate to the correct IPL set yourself.
I seem to never have much luck with the method. They never want to come out for me.
Thanks for the help. That link worked.
Thank you.
The FS541-BS14 is the main number you need for most parts. Th JD spec number has mostly to do with brand specific trim covers and some of the carburetor/ fuel system components in most cases.
Other than that, the base engine is the same across all aftermarket brands these engines were used on.
