GearHead36
- Apr 26, 2023
- 449
I have a Cub Cadet Pro Z 154S with a Kohler Confidant EZT750-3011 (747cc, 27HP, EFI) engine. I believe the previous owner neglected it. At 385 hours, I found that the cooling fins were almost completely blocked. I cleaned them out, adjusted the valves, and did the typical year-end maintenance (change oil, sharpen blades, etc). It ran better, and ran for almost two seasons, then died about a minute after a cold startup. Turns out, the camshaft gear is toast. It's almost completely disintegrated. See photo. I consider a camshaft similar to a fuse. If a fuse blows, I don't just replace it. I ask, why did it blow? Camshafts don't break if everything is working properly. The valve guides don't appear to have moved. Using two thumbs, I can move all 4 valves about 0.5", and they move smoothly. I can't detect any binding in the linkages (lifters, push rods, rocker arms, valves, etc). The push rods don't have any obvious bends. So... what caused the cam gear to disintegrate? Overheating? Can overheating alone cause that? It ran for almost two seasons after I repaired the problem that caused the overheating.
The pistons and valves don't show any signs of collisions. I'm guessing that this is a non-interference engine. OPE engines are fairly low stress. I'm guessing that they're all non-interference.
Since I believe the engine overheated, I bought a gasket kit. I'm going to replace the head gaskets, valve seals, main oil seal, intake & exhaust manifold gaskets, and of course, the camshaft. Do I need to replace anything else?
