I converted my 13HP Generac to LP, with a Quick Connect, so that I can hook it directly into my home LP line, which means it can run a very long time on my 500 gallon tank. The primary part was a Garretson Model Century KN Fuel Valve demand LP regulator, which I purchased directly from Dultmeier online. I made an injector nozzle into the carb. It's worked great, for many very long power outages over the years, no overheating, no loss of power output, which means it can still start and run my well. Dultmeier will have most any LP parts that you will need. If you're not the project type, then just buy a conversion kit for that engine.
