- Dec 7, 2022
- 2,261
Regardless of how thick your business card is, the .010” air gap still is correct for ignition coil to flywheel.Business cards are now different thicknesses. I just measured one at 0.030" and is what I use.
I have used .030 for decades. It works for me. I will try a Feeler Gauge o.o1o next time.Regardless of how thick your business card is, the .010” air gap still is correct for ignition coil to flywheel.
RightRegardless of how thick your business card is, the .010” air gap still is correct for ignition coil to flywheel.
Remember saws have a small coil to fit under the covering. These are more critical for proper air gap.such as chainsaws did not start as easy
