Portable and standby generators
Forest#2
I put pressure washers for the people that might use them once a year, and water(trash) pumps into that category also.
And they fail to winterize them. Surprise surprise.
That is where most of my good tiller and wood splitter engines come from.
The problem I have is most of the washers that I get in with bad pumps are the vertical style with the special short crankshaft that can't be used on anything else.
bullet bob
OK, since we've wandered over to this discussion, for those of us who are 'homeowners', and don't want to have to go see you guys every couple of years, what do you think of something like this?
Yey? Nay?
this is what i use, but there are other similar products
rv antifreeze is also a cheap solution to prevent pump freezing
Auto Doc's
I like the last words of the MITY-M ad where is says "store the machine in a garage or building that does not freeze".
All these companies are selling you is windshield washer fluid with an adapter on the container. RV pipe anti-freeze is basically the same stuff.
