Front blade
whiteshu
I have a snow blade that i have used on my 322 for years. I would like to mount it on my x738. What hardware do I need?
Probably best to call or go by the local JD dealer.
Auto Doc's
That is about a 30-year difference between chassis designs. Way too many differences and it would take a lot of custom adaption/ fabrication to fit the newer X738.
Auto Doc's
With a cutting torch, a stick welder and some heavy scrap metal anything is possible.
ashingde
I used the Deere OEM plow this morning on the x739 (2021). Deere's front hitch will allow you to hang the plow off the front end; and includes the hydraulics. Our previous Deere had a manual blade I had rebuilt (previous owner installed it all wrong and wore it to the point of breakage), but when I turned 70, I told my wife no mas. Ordered the x739 with 54" deck and 54" hydraulic snow plow. At the end of the season I drive the rig into the shed, lower and disconnect the front hitch, and the plow sits until next November.
