T110 No Longer Moving
Craftsman19
I recently picked up a Craftsman t110 2019 model. It runs fine and was working fine but stopped moving. The belt looks okay and snug but when I put it in forward neutral or reverse and let off the brake clutch there is a load on the motor and the belt starts smoking. Thanks
Does anyone know what this does or how it works.? I tried it but it did nothing to help get the mower moving again
Hello C.,
Welcome to the forum.
Whenever you post about a machine you are working on, we need the product label information off the machine. Usually, it is under the seat or on the seat base.
For anything engine related, we would need the numbers off of the engine itself. The engines are only supplied to the final assembly plant.
Craftsman is a private label box store brand name. These mowers are actually made by MTD, and earlier models were even made by Husqvarna
From the description of the problem, it has locked up a tensioner idler or stationary idle pulley for the drive belt.
The instruction label you asked about is basically how to set the pedal to maintain a constant set mowing speed aka as cruise control"
From the looks of the pulley, the belt got stuck from rust and "glued" itself to the pulley. This is not unusual in high humidity conditions or with a machine that sits out in the weather a lot.
