diesel z fuel gauge
johnbell47
I have a 2008 diesel z with digital fuel gauges that are inop. I am not familiar with this type of set up. It appears that the senders that are mounted in the bottom of the tank have 5 sensors in the tank, five wires coming off each. I assumed that each of the 5 sensor nodes has its own wire and senses when fuel is at that nodes level. I wired up five LED's to the five negative side wires with all plus side of the led's to the 12 volt side. I am showing 3 of the 5 lights. have not burned off any fuel or added any, so i really don't know if i am on the right track or not. Any suggestions would be appreciated. thanks
What about posting the actual model number?
Skippydiesel
You could just work out fuel used per hour of operation. Time elapse, from start, will then give you a fairly accurate fuel used/remaining. Simple!
he only failure point is the operators inattention. 😈
