9P702-0149-F1
Scrubcadet10
Moderator
Staff member
9P702-0149-F1
590556 carb is showing NLA?
Or is there a supercession I don't see
No supercede, but also check your date code because the 590556 is used before 18070100 and the 84002104 used after 18063000, The 84002104 is available
Hmmm this what I am coming up with from Amazon
799583 Carburetor Replace OE Part # 590556 591160 591979 593261 595656 for 300E 450E 500E 550E 08P502 8P502 09P602 09P702 Engines​
Now you may need to change out the main jet assy. as the 799583 is list on the power portal as for 09P602 series only. And 590556 is for the 09P702 series. Appears the only difference was the main jet assy.
It appears they are dropping the ball on things lately. But what in the heck do we expect out a company owned by a financial investment company.
Matter of fact I am finding at lot OEMs dropping the ball lately.
Scrubcadet10
Moderator
Staff member
Date code isnt anywhere.
No stampings on the valve cover
Check to see if it is Lazer etched into the side of the block.
depend when Briggs linking the serial to model I can look up the engine by serial
