AgentDoug
I know this is a lawn mower repair forum, but I figured I would try my luck. I bought a used Karcher G2500VH pressure washer with no water pump. Using a caliper, I found that the shaft from the Honda GCV 160 engine is exactly 20mm (a hair over 3/4"). I haven't been able to find this water pump anywhere. There are loads of 3/4" shaft water pumps out there, but I can't seem to find a 20mm version.
Any help or advice would be appreciated.
