Briggs Quantum 190cc rebuild?
skyline0964
Looking into possibly rebuilding a 190cc quantum engine? Am I wasting my time with these aluminum blocks? I looked online and can't seem to source a shortblock part# or verify if parts will swap over. Can't even seem to find the date code? Engine is off a 2006 SR4. Thought about trying a 7/8in SB and swapping over the crank? Thoughts? Any help would be highly appreciated. Thank you!
Engine
124T02-0203-b1
25mm x 3-5/32" shaft 1/4in keyway
Tiger Small Engine
Engine
124T02-0203-b1
Unless you want the experience and expense, it would be a hard no. Try to find a good used one maybe.
nbpt100
I am curious how you made out? Did you proceed with the engine rebuild or did you repower with an other engine? I am in the same or similar situation right now and if I can get a decent Connecting rod and piston at a good price I would prefer to rebuild but having trouble finding parts at a reasonable price. Inflation and likely supply chain issues are real in this sector of the economy.
Auto Doc's
Engine
124T02-0203-b1
How much play is in the piston when installed in the cylinder?
Is the cylinder scored badly?
Parts show to be available, but they are expensive.
Parts Tree:
nbpt100
There is no perceivable play in the piston. If I have it apart I usually like to replace the rings on an older engine. If not too expensive.
You can grab a ton of cheap pushers off facetrash marketplace. Either use the entire mower or rob the engine off one.
nbpt100
Yes , but you have to match the original Crank shaft or at least get it close and have the correct blade adaptor. Not impossible but it makes it a little harder than most think.
Forget trying to rebuild.
